Hej
Hittde detta när jag sökte på PY-online ang full size:
"65 and 66 decklids interchange. i think the trim is slightly different. regardless per the interchange in the 36th edition of hollanders they work.
fuel tank and trunk floor should be the same.
1/4's are the same except for the obvious sail panel contours and the portion that attaches to the tail panel.65/6 tailpanel sheetmetal are different."
Jag kan inte garantera, men där påstås det att de är lika..
// Thomas
Ingen Pontiac längre....däremot:
Belair 1955 2drht
El Camino 396SS
